Root !lost my wifi... Help!
Joe Eris
I re-flashed evil eris 4 today, & before I did I wiped data/factory then wiped dalvic. When I rebooted & got to the set up screen(set up google account ect.) the wifi worked! so I hit the toggle,& turned it off to make sure the 3G worked. Ever since then I cannot connect to my home wifi :confused: any suggestions?
If you go into Settings->Wireless & Networks-> WiFi settings, does it have an error next to your SSID name? If you click and tell it to reconnect, does it work?
Also, from that settings screen, I always set me eris using Menu->Advanced and set WiFi Sleep Policy to "never" - once I am connected, I want to stay that way.
In wireless & Networks it tries to connect, it says "obtaining ip address" then it says "unsuccessful"
Long click on the SSID, have it forget the WEP/WPA password, and try entering it again.
If that doesn't work I'd just either restore a known good NAND restore or wipe/reflash. Or try a different ROM.
OK I'll try that. Thank you so much
