Root Lost Recovery (Fixed)
yknujssab
Hello, I need some help. Ok so I was back on Collab 3.0.1 and had this brilliant idea on a way to boost up the volume on CM10. I was going to restore my PG backup and connect to QPST. Qpst has some volume tabs. Anyways, I went into recovery like always, backed up my collab and tried restoring PG. It failed, I figured it was because the recovery is different on PG's build. So I went ahead and flashed a fresh one. Everything went in fine. Hooked up to QPST put everything to the top volume level. For some reason I installed 2nd init and tried to go to recovery from there. I know, I can go into recovery from the power menu, I just can't remember why I did what i did. So I tried the 2nd init app and I got the dreaded Morning Call. I pulled the battery and rebooted. Booted up fine and I uninstalled the app. I tried to go into the recovery by using the power button, but I got morning call empty again. This time I pulled the battery and went into emergency mode. I figured I should just unbrick and start all over again, but I can't unbrick. I tried different firmware versions and they fail to install. Phone still boots and works fine, just can't get into recovery. What can I do? I'm at work now, but as soon as I get home I'll start messing with it again.
By the way, it just might be me, but it seems like the volume got better.:)
Finally Fixed It!!!!! I got home and did the unbrick and finally it took. Now I'm rooting again and restoring.
