Lost ringtones after deleting media storage data
robinta
As above, I was having issues with the media scanner running on so i tried deleting the media storage data.
Now when I go into sound options i only have 1 ringtone and notification to choose from. I cannot even find anything if I go into the zedge app option or into Music from this screen.
Using a file manager all the system files are still there under SYSTEM/MEDIA/AUDIO but the system is not recreating them for use somehow.
I did try a hard reset and then cleared cache; dalvik cache and fix permissions in recovery to no avail.
Anyone have any ideas other than reflash the ROM or factory reset ?
PS I am running Omega JB V11.
Thanks in advance
Thanks in advance
Usually a reboot will pick them up, assuming this has occurred as you have reset you should try getting scanmedia app from the play store and run it, that should find them for you
