Everything was working fine until yesterday. Started getting "x has been denied superuser permissions" messages. Ran both gingerbreak again and also the newer eman rooter. Here is the dump from root checker:
Superuser Application Status:
Superuser application - version 3.0.7 - is installed!
System File Properties for Root Access:
Standard Location
Check Command: ls -l /system/bin/su:
Result: -rwsr-sr-x 1 root root 22364 Aug 1 2008 /system/bin/su
Analysis: Setuid attribute present and root user ownership present. Root access is correctly configured for this file! Executing this file can grant root access!
Alternative Location
Check Command: ls -l /sbin/su:
Result: ls: /sbin/su: Permission denied
Analysis: File system permissions restricted and denied access.
Check Command: ls -l /system/xbin/sudo:
Result: ls: /system/xbin/sudo: No such file or directory
Analysis: File /system/xbin/sudo does not exist.
Standard Location
Check Command: ls -l /system/xbin/su:
Result: lrwxrwxrwx 1 root root 14 Jun 16 18:13 /system/xbin/su -> /system/bin/su
Analysis: File: /system/xbin/su is a symbolic link pointing to another file: /system/bin/su
Root User ID and Group ID Status:
SU binary not found or not operating properly
System Environment PATH: /sbin /vendor/bin /system/sbin /system/bin /system/xbin
ADB Shell Default User:
ADB shell setting for standard access, stored in default.prop, is configured as: root user - ro.secure=0
Rom is mirage 09292013. Any advice appreciated.
Standard Location
Standard Location
