Anthony2816
After installing the UKB_2.1_patch_nokernel.zip patch on top of a fresh install of Community Rom 2.0 (UKB_2_pbj50_fixed.zip), the Voltage Control app no longer works correctly. It pops up the message "Unsupported kernal detected. The kernal your device is running is incompatible with Voltage Control", and then will only run in "limited mode".
I had looked forward to playing with Voltage Control...is there a way to fix this?
My hunt for a solution is hampered by the fact I don't understand the word "kernal".
