Help Lost Wi-fi
dionick
Member
Hi all
Just got home from work and tried to connect to my wi-fi but its not working:mad:.It is showing the wi-fi sign in the notification bar but it is staying grey not white as it normally does:confused:.It is showing as connected in settings and makes no difference if i try to turn it on via my widget,quick settings or from the network menu.There is nothing wrong with my router or broadband as my computer is working fine:confused:.HELP PLEASE.
First step, install the free app 'WiFi Analyzer' and look for signal next to your router.
Harry
