Lotus Tablet PC LT-TB7/7B Help
Philnz
Hi, I have the above Tablet PC / phone it functions on the NZ net works 022 2 degrees and 027 Vodafone . But I cant send Txts via the 022 network. Receives ok.
Spoke to them today and we tried to input the SMSC number +64220227672 still comes back with Update Error this is via *#*#4636#*#*
The OS is Android 4.0.4
Lotus Tablet PC LT-TB7W/7B this is correct Subject missing the W
2 degrees tells me to contact the manufacturer and tell them of the error, there is no manufacturer Listed on any docs or box not in the manual or on the Tablet..
Can anyone here please suggest a fix etc .
Cheers Phil
Unfortunately I can't find anything on your tablet. The problem with the cheap tablets is that there is very little if any support for them.
Can tell you who the manufacturer is, probably not going to help much though.
Shenzhen Lotus Technology Co.,Ltd
LongTang Industrial Zone,
LongHua Street,
ShenZhen City,
China
Tel:0755-27043017
   0755-81700672
Fax:0755-27043017
...how's your Mandarin or Cantonese?
Cheers Phil
You trying to send regular SMS(text), and not MMS(picture messages). Normally AFAIK you shouldn't have to do any configuring to send SMS. MMS you have to configure the APN details. Is the SIM and carrier service OK, does the SIM send messages OK in another phone?
