I like using swype. The problem is that it will instantly learn any word you type manually. There are times I want to type a word by "hunt and peck" and by doing this on the swype keyboard it will learn every spelling mistake you have made.
On my phone this resulted in over ten misspellings of the word "the" for example.
The fix is simple, delete the following file to remove the custom dictionary and reboot
/data/data/com.swype.android.inputmethod/swypedata/udb/userdata.udb
It will be recreated as you use Swype normally.
Another interesting hack is to replace the file with one that contains words from another language. Here is a German one you can try http://forum.xda-developers.com/showpost.php?p=5150166&postcount=177 (get the userdata.zip)
