Root Low Audio Fix Kernels
flashed imo's with the volume fix, haven't really noticed a difference. If anything it seems a little more quite than it did before. Regardless no problems with it. Has anyone ever tried boosting the dB within the CM7 sound settings?
I use liquid thundersense's tol kit to boost my volume. I flashed the link for imo as well. Couldn't really tell much difference. Perhaps if I wasn't using the tool kit it would be a different story
I use volume+ with mid range boost so it's hard for me to tell too. But when I flashed the imo fix I had to lower the vol, it was just too loud. Have it set at 75% now and it's perfect.
It's not a huge difference, but the last couple notches are definitely louder on Imo's 3.5.11.
That is what i was thinking as well i think the first 3 or 4 sound the same, and that is normally all the louder i ever go, had media sound up last night all the way on accident and started playing a game and it was noticeably louder than normal.
