Low backlight on Z3+
I've replaced screen on my sony Z3+, everything works but backlight is very low
go to settings-display-brightness check it if its low. if yes just bright up the brightness
Hope that helps:)
That's not the reasson, I've checked this but the screen backlight is still low
do you send me a pic or video then i know how much low (lockscreen and screen). for example i got this for your device.
it was sony xperia z3 is the screen really low like your device . i got it from google. i am not sure its really similar to your device.
can you just tell me the way ho to fix it?
If the Settings/Display/Brightness level control makes no difference, and Adaptive brightness is OFF, then you may have a defective LCD panel.
Is the replacement a genuine Sony part? if not then it may simply be sub-standard.
you replaced a new screen on your z3 right? does your previous screen works well with backlight? if your answer is yes then i think you need to place a better screen on your phone.
Hope that helps:)
the thing is that i've dropped my phone in to the sea, the only thing that was damaged was the screen thats why i've replaced it
i mean to say, before dropping in the sea is your phones backlight working well?. after dropping on the sea your phone backlight low. i am waiting for your response.:)
Yes, before dropping the screen was well
i think there is a problem with backlight system. water cuase damage.
video has a same problem of backlight. if you didnot like this type of trick then you need to test or repair it to a electrician.
Hope that helps:)
