basscommander
I apologize if this is a question that has been asked before. But, I wasn't able to find a thread that really answered my question.
I run Aloysius 2.1 as my ROM, and I run Darktremor 2.7 apps2sd. I have a 16gb sd card, and it is partitioned. The apps that I download are being saved to the sd card. But, yesterday, I had to data/factory reset, wipe dalvik-cache, and wipe SD:ext partition. With the help of Kelmar I was able to get things working again.
After I got it working, and did a nandroid restore, I still had to go re-download all the apps that I had. Prior to doing this my internal storage showed around 40-41mb. It now shows only 23mb after re-downloading all the apps I had. I know that the apps are being saved to my sd card, but, I would like to figure out why my internal memory is still decreasing, and why it is so low in the first place since I am running apps2sd???
Thank you in advance for the help/info!
After I got it working, and did a nandroid restore, I still had to go re-download all the apps that I had. Prior to doing this my internal storage showed around 40-41mb. It now shows only 23mb after re-downloading all the apps I had. I know that the apps are being saved to my sd card, but, I would like to figure out why my internal memory is still decreasing, and why it is so low in the first place since I am running apps2sd???Thank you in advance for the help/info!
