Help Low internal memory
I just bought mine 4 days ago and have the same problem. All I downloaded was facebook. The button to move apps to the sd card will not activate for any apps the phone came with so what do i do??? Please help!
I have exactly the same issue steve, it does not give you the option to move it to the memory card!!!!:mad:
If you're willing to spend a little time on this, the guide at [Guide] Move more (most) apps to SD without root (Simplified) will help you get some of those apps moved. This is in the Desire forum, but it works on the Wildfire S. I've done it myself.
The hardest part is installing the Android SDK tools. I used this guide to get the job done: Howto: Install the Android SDK
You can use the Mini SDK found here: http://androidforums.com/faqs/443072-adb-guide-updated-12-05-2011-a.html
It's easier to install and because you only need the ADB.exe, that's pretty much all it installs. :)
My phone isn't allowing me to download anything. i tried downloading google+ so i can send my photos to gmail because my phone wont allow me to do nearly anything right now cuz it's internal memory is so low! i've had this phone less than 2 weeks. how can i save my pics and whatever else to SD card/gmail, whatevers best. i just need a bunch of help on how to clear up some memory and keep it that way! i have no idea what or how to sdk or abd lol
