ok tried searching around havent found much luck on fixing the HTC Desire Low internal storage issue. i virtually have no apps installed on the phone besides the basics like google maps and navigation, flash, facebook, msn. and all the games i have installed are on SD card only like maybe 5 games if that. and my contacts are gmail.
so how do i fix this problem anytime i try to add a new app or game and if the option isnt there to move to SD card or is, i still get the warming.
I dont really want to root, and ive heard about Andriod SDK but couldnt find much info on how to run it properly
questions is... how do i fix this without rooting, im not against rooting i just dont want to go through the hassel of doing it and possibly bricking it.
1/ how do i fix this, i was just going to reformat to factory default and start from scratch with something that would help clean up internal storage
2/ if i redo my contacts and save them to SD or Sim (one of the options) istead of gmail will that save up room?
3/ does android SDK that force all apps/games to automatically install to the SD card and is it good for HTC Desire?
