Hi there!
So I just picked up my Galaxy Nexus a couple of hours ago and was very excited to see how everything worked and looked.
I was especially looking forward to seeing this beautiful screen that everyone talks about.
Unfortunately I very quickly noticed some kind of pattern on the screen.
It is looks like small lines going all the way from the top to the bottom and others from side to side.
I guess you can say that the pattern looks like the one from the Burberry clothes.
The pattern stays the same no matter how you move around on the screen and where you are in the system.
It is very easy to see it. Just find a white background on the screen (a homepage etc.) and set the brightness to between 10-50%.
Another way to see it is, if you have a white background and then turn the brightness to 90-100%. Then pull down the notification bar.
The gray notification bar-area now clearly shows the pattern once again.
Can anyone please try the above and inform me if this is just my screen or if it is a common issue with this phone.
I would really appreciate your feed-back before I decide to return the phone.
