not sure what bug you are referring to.
On the Incredible. I have 449 mb of memory on the phone for apps and games and 16 gb memory card and every time I want to install new app such as Google Earth or a game like Need for Speed, I get the "low on space . Go to manage applications...and then I have to get rid if some heavy on data apps to solve it. Even on the apps that you can storage on the memory card!![]()
hmm, never had that issue on mine.
The DX has 8GB of RAM for apps/data so you really never run out.
From my DInc experience it suffers from have only "x" amount of RAM for both apps/data storage and the 8GB of internal memory is separate. The DX has 8GB of RAM for apps/data so you really never run out. From the specs on the TB it looks like it has 8GB of app/data RAM available with 32gb microSDHC card.
I also experience this problem from time to time. I do not have a ton of apps and I delete my old texts daily. It's a software flaw in the Incredible. I used to read of others having this problem and thought that I was immune to it then one day presto there it was! I found that uninstalling the K-9 Email app seemed to resolve the problem....temporarily. It reappeared after a couple of months of being symptom free. Now it's gone again after deleting some small apps. Very frustrating but I didn't want you to be on an island here canito. Like you I hope that the Thunderbolt doesn't have this problem. I would have to say that's the only real quirk with my Incredible.
