What size partition do you have? Running a2sd at 1024 you should have almost 1GB. You can check in terminal emulator
Su -
A2sd check
The sections are set up properly if it says []
They are NOT set right if you see [ ]
If not set up properly, in terminal as su
Enter a2sd repair
Reboot
Go back into terminal and run a2sd check again
If still not set up right enter a2sd remove
Reboot
After boot up go to apps should see a2sdgui
Open click move apps
Will reboot one more time
Open a2sdgui again go to second tab
Move dalvik cache
Reboot again
Profit!
I did all of that up to the 2nd reboot.... problem is, I can't find a2sd in my apps, even though the terminal is giving me dialogue for it.
