Low Memory Killer Levels
Terabethia
Android Expert
To start with I just want to say that I do not have a problem with Low Memory notifications and am not asking for help.
Okay... so I have an app called Android System Info. It's handy, has tons of information in it. I was just looking through the menu and noticed "Low Memory Killer Levels", which seem to list the level at which this notification should display. Mine says:
Foreground App: 6:00MB
Visible App: 8:00MB
Secondary Server: 16:00MB
Hidden App: 20:00MB
Content Provider: 22:00MB
Empty App: 24:00MB
There doesn't seem to be a way to adjust these settings, at least not in the app. But I thought that maybe that information would be useful to people having the memory low notification.
Or maybe someone can figure out a way to change those settings within the phone. Set it to a lower level or something.
i cant believe no ones answered this. i have the same problem. i cant even get downtown and back before my battery dies. its been off the charger for 5 minutes and has lost 11% already.
Visible App: 8:00MB
Hidden App: 20:00MB
Empty App: 24:00MB
There are two ways for it:
1. MinfreeManager app from Market offer various levels of lowmem killing such as moderate, agressive,..., you can manualy change nummbers, too;
2. Darktremor app2sd script, with it you can move apps to sd (ext) and via adb change lowmemory killer level (of course, a lot of other things you can do with adb).
Root is required.
