Help Low memory limit when installing apps from Market..
ckeegan
OK, can't really figure this out. I am unable to successfully update any apps (which are showing on the update list), and I'm not able to install any new apps.
I literally have no idea what's going on, but could it be because my internal storage is almost full? I have .97GB free, and I kind figured I would leave that buffer. Not enough of a buffer?
Could that be what's causing my app issues? Anyone else having or had any similar issues?
Thanks in advance for the help.
So last night I got rid of 1.5gb, and it fixed the issue. However today, same issue, and I haven't added anything more than 300mb. I currently have 2.2gb free, and can't update any apps. :mad:
They really need to get microSD support working asap, assuming that's even the cause of my issue.
I have noticed that sometimes the market gets stuck when downloading if you switch to another app. Have you tried powering down then back up?
It wasn't actually freezing up. I would hit install, it would download, install, and then say unsucessful. Same for updates to existing apps. I have tried powering down a few times, but it never resolved the issue.
I actually did a factory reset this morning. Reloaded everything I had before, and no problems so far.
Are you connecting via wifi or over 3g?
Wi-Fi.
I'm having pretty much the same problem.
I thought it was becuase I changed my passwords. I cleared everything off, did a factory reset, and it went into putting everything back on, I thought I was doing well.
Then I put my music back in there and other things, and now it's not updating or installing apps.
I found out that if you have less than 2.5GB of memory left the market will not allow you to install any additional apps. You will get a installation was unsuccessful message.
Also you can not side load apps either.
