Help Low memory warning from Blink app?
PSUlion01
Member
Quick question... I'm occasionally getting an alert from the app Blink that tells me i'm running low on memory. What exactly does this mean? Are too many apps running, or is too much simply installed?
How do I go about reviewing the memory being used, and then how to free some up? What amount or % of memory should be free?
Thanks and sorry if this is a simple question... The X is my first Android device so I'm still learning the ropes.
Just go into Blink and disable it. Android handles memory very well. You don't have to worry about that. It will release older programs to make room for new ones that open when it needs to.
If it makes you feel better I got those same warnings using Blink on my X. I wouldn't worry about it.
