Low memory
  • Start date Start date
A
Android Question
Guest
I have an Optimus LG L9. It has limited memory I can not move apps from internal memory to my 8GB memory card. HELP...
Unfortunately, App2SD disappeared from more recent versions of Android.
If you check out the rooting section of the LG L9 sub-forum, you should be able to find out how to root your phone and get some replacement for App2SD.
