I will start out by saying I am fairly new at all this and sorry if I duplicate this issue. But no forums seem to be helping. I have gone though about a million different forums and tried many things and every time I sneeze my phone says low on space.
First thing I did was root my phone using the revoked method and am now running Android 2.2.
I have installed and used the SDK options to pull out the bloateware and apps that I have no use for. I pulled out all the .apk and .odex files relating to these and pulled about 6 or so apps. I then did a Wipe Dalvik Cache and rebooted the phone,
Then as per another forum I keep all my caches clean.
And as per another forum I used APP2SD and crammed all that will go to my SD card.
I have my mail clients set to keep minimal on the phone.
I keep recent calls empty.
I keep my sms & mms at almost nothing.
I keep browser clean and have 0 bookmarks.
I basically have absolutely every thing set to minimums and cleaned as per may other forums from here.
I have maybe 7 apps that I use all the time and no other.
And sneeze and my phone pops up storage is low.
*I have been reading on flashing new ROMS and not sure if there is a smaller ROM that my help with less junk in it???? Am I barking up the wrong tree?
*When I rooted with revoked did i get a new ROM flashed or would it be stock?
Are there any other options available??
). Depending on which APP2SD you used, it may not move all of the program (a program can consist of the program itself, the Dalvik cache, libraries, and data).
