"Low on space" Notification.
Yeah it kinda sucks that they don't give you enough space to save your apps. You shouldn't have to delete anything, especially if you purchased it. I wish you could just open everything from the sd card. If that is possible, please let me know
apparently that only works if your root the phone. seems a little too complicated and i dont want to screw anything up.
How many apps do you have installed?? I still have 43MB available and I have 25 or so apps... Hopefully they're quick in releasing the 2.2 update so you guys can store on the SD card.
I so need to store apps on sd.
This is what I'm currently working with. As you will see, my SD card is waiting patiently for the arrival of apps.
I counted my installed apps last night just to see how many you guys have to have installed(or perhaps you are all just dling games which take up loads of space).
I had over 40 apps installed and still had 28MB left. You're all a bunch of storage whores! :D
This may be a no brainer but you have to go into the applications manager it settings and uninstall apps. If you just delete them from the application home page by long press and dragging to the trash, they are not uninstalled.
mmm I just counted around 40 with 23 MBs left....
I'm testing the 2nd alpha from the liberatedAria folks. It's a CM6(Froyo) based ROM. I'll report back as to how the ROM is working. If it works well enough I recommend you flash it so you can move your apps to the SD card.
