How do you guys live with the small storage space on the Elite? I know that you can partition an SD card and use Link2SD, but is there any other way? I am slowly running out of both system and internal memory. Suggestions are helpful.
Thank you!
Link2SD actually doesn't work with this phone. Phenom has figured out how to swap the internal and external sd cards on his CM9 Rom so you can store apps on your external sd card.
