Help Low Volume after Notification
mertbba
Hello everyone,
I am using Triumph with CM7(Tickerguy's Build). I use the phone to listen to music on the road. When I plug in the AUX cable, the volume is very reasonable. However, when I get a notification(email, any kind) the volume decreases significantly. I looked at the sound settings but couldn't fix the problem.
Thanks
This is a known issue with the phone. It doesn't matter which ROM you use. You can pause the music for a bit (5-6 sec) and it will return to the higher volume. There are a few other ways to do this as well that various people have reported to work for them.
This is bugging me, my lock screen sound is very low all the time since I got cm7, I've looked into the same settings, and it's up Max, unless the rom has a hidden option I can't find
