Help LPP FC's
After the update to GB, I was getting them every time I would swipe homescreens, so I dumped it and went with GoLauncher EX and bought Android Pro Widgets from the Market. The developer of APW is very responsive and you get several widgets to choose from. The themes are still limited, but more are expected. The widget customization it provides are better than LPP, IMHO.
Do you use Ti Backup?
I had trouble when I was restoring LPP from ROM to ROM though Ti Backup. Since then, I just backup LPP using the built-in backup function, then install it through the market and restore my settings. No problems since then.
Try uninstalling it and reinstalling.
Is anyone else getting the obnoxious fcs every time your phone starts up with launcher pro? So annoying
There is a strange delay after a reboot. If I interact with the screens Android offers to Force Close LP (or keep waiting). If I just wait, everything is fine. Is this what you're seeing?
I have used LPP for nearly a year. I always loved it but occassionally had FC issues. I tried GoLauncher EX yesterday. It is now my default home. Everything I loved about LPP but with some UI improvements.
Same problem here and very annoying. Since this is a paid app, no support for this problem really bugs me.
Any help would be greatly appreciated. Stock X with the new update installed (it has been doing this for awhile now)
Only way to maybe fix is to fix permissions. But if you're stock, that ends that. Try Go Launcher (its free) or my recommendation of ADW EX.
I've had the same problem with LPP since the GB update and with the 2nd Init ROMs. I have not found a way to fix it.
Seriously, check these out if you haven't already. Aside from the currently limited themes, APW is almost identical to LPP's widgets and GO EX is pretty smooth (and always updating, so feedback to both devs is a good idea)
I've tried and really liked Go Launcher EX but it was pretty laggy on my phone. LPP only FC's when first booting up so it isn't a big deal really, I just hope it will eventually be fixed.
