AZ_Biker
First hiccup with rooted TB. After getting evertyhing set up with Tshed and imo 6.1, I powered off, vol down power button to hboot, said no image found, (yes the file is named PG05IMG.zip and placed in sd card root) asked if I wanted to update, vol up for yes, updated mk9 and img, all good, power btn to reboot. Once up and running, I switch from 3g to 4g, takes me to phone info, no LTE/EvDO option. Top to bottom options are; WCDMA preferred, GSM only, WCDMA only, GSM auto(PRL), CDMA auto(PRL), CDMA only, EvDO only, GSM/CDMA auto(PRL), Unknown... When I try to select GSM/CDMA (prior to root the option was LTE/CDMA auto(PRL) it's kicks me back to CDMA auto(PRL). Under settings, about phone, the baseband shows 1.49.00.0406w_1, 0.01.79.0331w_1.... Any suggestions? Thanks in advance.
