Help LTE issues
You have to do all the steps I listed above in order for LTE to work. The .48 or .53 radios have code that disables the use of LTE when using them, so downgrading to the .33 radio is necessary. That dial code is one of the steps required. Also needed is the build.prop and apn changes in order to tell the device how to connect to lte services and from which carrier to connect to.
  • Like
Reactions: Lineman69
Upvote 0
BEST TECH IN 2023
Smartphones
