Lumiread downgrade
Hello this is my first post. I recently upgraded my android os and since then i cannot find the night reading feature of my lumiread app wich i really loved and used very often. I am missing something or is this an unwanted downgrade.....i am disapointed...:stupido3:
Welcome to Android Forums bernieflyer.:)
I've moved this to Android Applications as I think you'll get better help here.:)
I'm afraid I can't give you a solution, but you are not the only one who seems to have lost it from their tablet, as seen here.
Is this app a specific one that comes with your tablet? I can't find much info about it asides from being on the Acer Iconia series.
Let us know which Iconia tab you have and we'll get you moved there. Device owners would probably be able to help the best.
Hey bernieflyer, I have an A500, and after doing some checking around, it looks like you may be out of luck for the moment. Something about ICS forced Acer to remove the night mode. Folks over at xda have tried to install the apk from the honeycomb version, but the night mode won't work. Someone may figure out a way to mod the software to get it to work, or at least similar to the original night mode, but for right now, its either white or parchment background.
If you are interested in another app, I have read that "Aldiko Book Reader" has a great night mode, you may check that one out.
Hope this helps.
