Michael.aw
I've had my M.X.HC3.2 for one week know and I'm very satisfied with it. With the high quality of the hardware as well as the software.
What I'm thinking of doing with this one thread is to come back and edit (add to it) each time I think I've found a discovery.
My discovery's for now will tend to be simple, not too technical aspects to them.
Such as, (Comments, corrections, fixes, etc welcomed!)
01. In this forum search, I have to use Advanced Search because the first drop down box isn't allowing me to type in, when I start to type the keyboard goes off.
02. Swype doesn't work yet in HC3.2. (As of July, 2011)
03. Using Google +, full function not available in App, better to use browser and use web page gives all functions.
04. AVG anti-virus and more is available Thru 'Market'.
05. Press and Hold, the up arrow key on keyboard until a line shows at bottom of up arrow button locks in upper case in alphabet mode.
06. Skype is available thru 'Market'.
07. With keypad open, in lower left off screen is an icon that looks like a dial with a pointer. Press it and a menu appears, press Android keyboard settings, from here you can customize text correction (spelling suggestions will be visable as well as other word suggestions.
08. I think, not sure, if you allow screen to go blank by itself, via screen time out settings which can be customized for various time durations, then you open Apps and email inbox alarm sound all seem to stay active. But if you press and hold the on/off button on back of case the power goes completely off and all open apps close and no email arrival alarm.
