droid51378
I am following the XDA dev forums instructions, but when I get to step 2 ... I am lost lol.
Here it is:
Now, for rooting.
First, go to Settings > Applications>Development, and make sure USB Debugging is checked on your phone.
1. Download Asroot2 (http://zenthought.org/tmp/asroot2) and move it to your SDK/tools directory
2. Navigate to your SDK/tools folder (cd ~/Documents/Android/SDK/tools for me)(~ replaces /User/%Username% if you didn't know)
3. Then type:
./adb push asroot2 /data/local/
./adb shell chmod 0755 /data/local/asroot2
./adb shell
/data/local/asroot2 /system/bin/sh
And you should get:
$ /data/local/asroot2 /system/bin/sh
[+] Using newer pipe_inode_info layout
Opening: /proc/857/fd/3
SUCCESS: Enjoy the shell.
4. Then type:
mount -o remount,rw -t yaffs2 /dev/block/mtdblock3 /system
cd /system/bin
cat sh > su
chmod 4775 su
At this point you should have root access.
I do not understand where I am supposed to type in the info. I have never done this before, but would like to.
Thanks
Here it is:
Now, for rooting.
3. Then type:
./adb shell
And you should get:
4. Then type:
cd /system/bin
cat sh > su
chmod 4775 su
Thanks
