Magnetic Case Issue
Hello Guys,Am Using A Leather Flip Case With A Magnet For My Galaxy Note 2 And I Have Found That While Inside The Case,The S Pen Seemed To Malfunction On A Certain Part Of The Screen And While Investigating I Found It To Be The Problem Caused By The Magnet Because It Works Perfectly When I Take It Out From The Case..The Magnet Is Exactly Between The NFC And The Speaker At The Back And My S Pen Doesnt Work Around That Region On The Screen...So I Want To Know If The Magnet Will Cause Some Permanent Problems To The Device And The NFC! Thank You!!!
Not sure about long term issues, but most people have reported magnetic cases cause problems with S-pen
Yes, I've seen a few complaints about magnetic kickstands on Seidio cases causing a problem too. But it seems only certain ones, other people report no problems with the same case on the same phone.
Either way, I would avoid a case with a magnet.
