Help Major Battery DRAIN...
dinjc
I recently upgraded to android ICS 4.0.4 from 4.0.3 with the hope of the battery issue no longer an issue with my nexus s...
Though my battery drains around 1% every 3-5minutes with normal use, as in just scrolling and going through settings, very light use. I have wiped it factory wiped it, i have installed new roms, uninstalled apps i even disabled some the high % wasting applications... and when i'm playing a game or something it drops around 10% in ten - fifteen minutes, sometimes drops more.
When my screen is sleeping it takes around 3% every hour... and when i turn it on my battery drops majorly fast. My screen takes up around 50% of my battery when I look at the battery stats.
It is very annoying and i have search around on forums but cannot find a solution...
