phillyundead
Have had the Edge for 15 days so far and it's been nothing but trouble. It's even more frustrating that it's much more expensive than the Note 4 and coming from a 4 and seeing the crappier quality.
Had one with screen issues and got a replacement right away.
Got the replacement and this thing is just bogus. My girlfriends Edge has similar issues but not as intense.
Phone over heats constantly. Even when the screen is off. I can't figure it out.
Screen sensitivity is weak. Even with it turned up.
After lollipop, the phone dies twice as fast as before.
Buttons don't respond right away all the time.
Sometimes will full on freeze and force me to pull the battery.
Will not allow me to connect a flash drive via the otg cable. I was always able to on the note 4 even without root.
Constant lag. Probably thanks to AT&T and all of their annoying apps on top of Sammy. According to Clean Master and system settings all the AT&T apps still run even while disabled.
If this is how a $945.00 phone is gonna perform then I don't want a phone. I finally convinced myself to give in and pay extra for the edge but dear god do I regret it.
Does anyone have any of these problems? It's crippling both of the Note Edges that we have. AT&T will only offer a replacement because no more remorse period. I might just cancel AT&T all together. No root means no way.
