Major problem : Urgent help
Phone : Micromax A100
My phone is locked , pattern lock forgot ..used up all 30 times..
Now the gmail lock is there , which keeps saying invalid password even though its correct as my net is turned off ( Both data and Wlan)
Is there anyway to turn on net ??? ( Locked phone)
Then only option is Hard-reset phone...i have reached the developer screen with 5 options...but there are no options of pressing enter ...on wipe data/factory reset...i mean how to select it ??
I can move up down by volume keys ..but there is only a power button left , which does not select it ..How to select factory reset now..
Please help
Idk jack about Micromax but most Android bootloaders are accessed from some combo of external button presses while the phone is in an OFF state so pull the battery and then replace if you can't get it off by other means. Then try pressing volume up and the power button at the same time, or volume down and power button etc. Sorry, best I can give you right off the bat without more research.
The major problem is selection ..How to select an option ?
There are no buttons ...!!
Usually done with the volume rocker (to scroll thorugh bootloader options and power button to select one). I just watched a vid on the A100 and it showed a volume rocker on the left side and a power button on the right? You can't use those? :hmmmm2:
Im using those to scroll up and down ....But there is no button to select ..i tried power button ...not getting selected . It comes "The new key is 114" or the new key is 116"
Shouldnt there be a confirmation ask before wipe data/factory reset ?
I'm just really surprised that the power button won't select it. So you are in the stock recovery right? What are all the options you see in the stock recovery right now?
Please help
Select by long pressing by hitting rite in between the volume rocker
