Root make CPU governor stick!
if you want your CPU governor to stick, search for the thread called
No-frills CPU governor stick
...or, if you want to know how to do it without the app:
create a script with this in it...
Code:
#/system/bin/sh
while true
do
 echo conservative > /sys/devices/system/cpu/cpu0/cpufreq/scaling_governor
 sleep 600
done
(where it says 'conservative', insert your preferred cpu governor setting)
save the script as
/data/cpuGov.sh
then edit this file:
/init.rc
add these two lines to the end of the file:
Code:
#run cpu governor script
/system/bin/sh /data/cpuGov.sh &
if you do this it will run the script at start-up of your LG esteem, to re-set your preferred CPU governor every 10 minutes (change the 'sleep' time in the script to any number of seconds that works for you).
I used the app, Root Browser Lite, to help me create and edit text files as root. I also used Terminal Emulator and BusyBox Free. If your cpuGov.sh file is not executable you can make it executable with this busybox command (from the terminal, as root) chmod 777 /data/cpuGov.sh
Code:
#/system/bin/sh
while true
do
 sleep 600
done
save the script as
/data/cpuGov.sh
/init.rc
Code:
No sir, get cpu no frills "classic" then click safety valve & no using outside sources. Works perfectly
