Make external memory internal memory help
Yes, is possible by swapping the lines in red below inside vold.fstab file located in /ect folder.
first line is under # internal sdcard
second line under # external sdcard
just swap this lines:
dev_mount sdcard /storage/sdcard0 11 /devices/platform/dw_mmc/mmc_host/mmc0/mmc0 encryptable_nonremovable
dev_mount sdcard1 /storage/extSdCard auto /devices/virtual/block/cyasblkdevblk0
for this lines:
dev_mount sdcard1 /storage/extSdCard 11 /devices/platform/dw_mmc/mmc_host/mmc0/mmc0 encryptable_nonremovable
dev_mount sdcard /storage/sdcard0 auto /devices/virtual/block/cyasblkdevblk0
save and reboot device
NOTE:
Before you make any changes to your Firmware ALWAYS,ALWAYS MAKE A BACKUP of your DEVICE and your internal/external SdCard . I'M NOT RESPONSIBLE IF YOU BRICK YOUR DEVICE, follow the instruccions @ your own risk. This MOD has been tested by ME.
for this lines:
Mine says Dev_mount sdcard /mnt/sdcard 11 /devices on that first line, should what I enter be different than yours, or stay the same? Because mine doesn't say everything yours does.
Swap everything before 11 on the first line and everything before auto on the second line, or you can pm me a copy of your vold.fstab file and ill do it for you.
