Root make my sdk compatible with gingerbread cm7 and froyo
Hi can someone point me to a simple solution. I have a startup froyo ask environment that. Works well for me but it's froyo. I was able to screencast using it. When I connect I get a very blurry screen rendering as I'm on cm7 now. I'm assuming I need some type of update as the ask can render flawlessly from my experiences with group. I was hoping I could have my ask recognize froyo "and" cm7 gingerbread? Is it as simple as downloading a gingerbread package? Can the ask recognize both froyo and cm7? I didn't post in the setting IP topic below because theoretically alliance "might" need is a link to a patch or update and the installation instructions for using both. Thanks in advance.
Error key
Ask= sdk
Alliance= all I need
Setting IP= setting up sdk environment
group= froyo
