Help Make of TV isn't on Smart Remote
Shave
Member
So i have an Alba TV, which isn't on the list of makes. I was wondering if anyone knew of a workaround or such to get it to work.
What application? I've been looking for applications that use the on-board IR controller, but as of yet have not found any. I'd love to be able to actually use it (Peel doesn't work right for me. Don't have cable, and changing channels is about all it seems to be good at)
It is only supposed to change channels and not replace the whole remote. Also there are different modes in he app itself once you connect to a device. I have not checked if there are any apps to replace Peel, I only usse mine for simple actions, nothing crazy.
That make two of us I have tried loads of them and cant find one that works. Peel is a piece of crap and the website is just as bad and customer service is non excistant.
Hi
I wont use s $600 Note to use as remote which costs $10 or so. Lets ot try to use each & every feature wout using cost benefit analysis :)
