Help Making a Dodol Wallpaper
la sal
Android Expert
It works great for making a Portrait Wallpaper from my Gallery.
When I try to make a wallpaper from P3Droid Star Wars Wallpaper, I am unable to resize it with this app.
Any suggestions?
idk what that is , but have u try resizing it on ur computer frist ?
*** text red cross 90999 and Donate to Japan ****
If you do resize any of the pictures, Use paint (If you are using Windows). Click the "Maintain Aspect Ratio" box. Then put in this under pixels > 320 x 480. ^^.
Mine is the 10,000 one. ^^. Feel free to try different ones though. You won't truly be happy unless you've found the one you like the best. It's an awesome thing about Android, You've always got plenty of options!
