Making my Droid X Current
On the maderstock post it says "If you attempt to create a backup or flash a rom post maderstcok installation you're going to have a paperweight." Does this mean I won't be able to install liberty post upgrade?
No, it means there is a precise sequence that you have to follow. Do it *exactly* the way he tells you, and you'll be OK. If you do anything other than what he tells you to do, you could end up with a bricked phone.
-Mike
