making sure I have a skyrocket
spikeithard
Android Expert
My phone has the four soft key buttons at the bottom. (menu, home, return and search)
its headphone spot is on the top left. the camera on the back is more vertical than horizontal. the speaker is on the back in the bottom right corner. and the screen does go almost right down to just above the 4 buttons at the bottom.
sounds like the skyrocket but I just want to make sure others have the same features. I am on Rogers in Canada.
thanks
To be sure, go into Settings >> About Phone. Line #4 from the top: "Model Number" should be able to confirm it for you. I believe that the Rogers version is SGH-i727R (US/ATT is just i727).
That should set your mind completely at ease, once and for all.
you are correct sir. thank you
