greg schmeg
Guest
Ok. So i followed guyphs' "F29 root achieved!"post and followed his posted links to get the cwm and cm10 zip that i needed for this switching of roms. I have agat 054, so i went there, at that point (wasnt positive i needed to), i wiped all the data, cache, and dalvik. I.then proceeded to flash cwm. Flashed over np, i rebooted to recovery, which then brought me from agat to cwm. From there, i wiped everything again. Then proceeded to install cm10 zip. Two seconds into it, the little android man falls on his back and its.saying.that the.upgrade failed. Can amyone tell if im doing something wrong anywhere in that process?
I figured maybe because i didnt.download the cm zip from my computer and i instead used my phone, maybe i got a.corrupt download?
I just restored my old nandroid np.
Also, i need to restore apps.with titanium backup when i do get.flashed over to cm10. do i need the app on my external sd card or will it.get pulled up in cm10 once im there if its on my internal sd card? I need the task manager and voicemail and others.
Thank you in advance.for your time and efforts.
GREG
GREG
