Help Makng go launcher default
Bunnyko
I recently got the samsung galaxy s2 for virgin mobile. having had go launcher on my triumph and liking it alot there, i decided to download it for my new phone. all was well until virgin mobile downloaded an essentials package that changed my default home screen from GO to it. I cannot seem to find a way to change it back. Looking at others who have had this problems on other phones has lead me to a dead end:
menu> settings> apps> downloaded> go launcher ex
then the directions say to change it to default here, but my only options are: force stop, uninstall and clear data.
Any suggestions on getting o to be my default again?
If it's running touchwiz look for the app called "TWlaucher" and click "clear defaults" this should allow you to choose your homescreen. If you can't find it then uninstall go launcher and reinstall it and the option to make it your default should come up again.
