Help Manage applications stuck on 'Computing'
NialllM
Hi,
When I go to the Manage Applications area of settings, the S2 gets stuck on 'Computing', and gets stuck when trying to uninstall apps/move them to SD card/clear data & cache. Does anyone know how to solve this problem?
I have done a factory reset, which has made no difference, yet occasionally when I restart the phone and uninstall an app straight after restarting it uninstalls it fine, but otherwise it takes ages (5 mins+) to uninstall an app, and it has lots of trouble freezing when trying to clear data/move to SD card.
All my apps are now on the internal memory, they were on the SD before, but it doesn't seem to make any difference. Scanned for viruses and found none. It has trouble downloading and installing apps from the Play store too. Does anyone have a fix?
Thanks,
Niall
