B bad1550 Well-Known Member Jan 6, 2011 #1 How can I change the notification sounds for my yahoo mail account. The evo only allows gmail changes Thx
ScorpDX Android Expert Jan 6, 2011 #2 Are you using the yahoo mail app? You can change it in the settings
B bad1550 Well-Known Member Jan 6, 2011 #3 ScorpDX said: Are you using the yahoo mail app? You can change it in the settings Click to expand... I just checked - I went into Menu, options, general settings and it only gives option under notification sounds to check or uncheck it How do I change the sound? Thx
ScorpDX Android Expert Jan 6, 2011 #4 Good question...I don't see it now. Maybe that was the last version
B bad1550 Well-Known Member Jan 6, 2011 #5 ScorpDX said: Good question...I don't see it now. Maybe that was the last version Click to expand... Thanks
