Help Manual resets due to Browser issues?
NOVAdroid2151
Good morning all, I was hoping you all may be able to help or just agree with me this morning...
I routinely switch from WiFi to 3G because I do not have it at work but have WiFi at home. Anyways, when I go back and forth between the two, I find myself getting caught in an issue with my browser(stock) on the X..
If I'm on Wifi and use the browser then turn it off and start to use 3G, the browser will not load any pages. I have a feeling this is tied to how it connects but I am not sure if I'm the only one.
Is there a solution to this? The only way I can fix it is to hold the top button and the home screen and do a manual reset.
Thanks!
it should not matter unless you are switching as you are surfing a page, in that case refresh the browser page and it should come right up
