Root Manually set vsel values?
darkcyber
Android Expert
Is there a way to set the vsel values? I have setcpu, droid overclock, and quick overclock and I see where to set different mhz speeds but no where to manually set the maximum vsel value for each.
Just use QuickClock Advanced if you already have it. Open it select module then calibrate. Leave it alone for a few minutes as it determines your lowest stable vsel. Then from there it'll create a buffer and you will have a base vsel to work with.
