Manually turn off soft key lights!!!
kishin14
I watch a lot of videos right before I go to bed. It has to be in the dark b/c my wife is usually sleeping right next to me. As much as I love the HD screen, the one thing that did annoy me was that the red soft keys would stay lit while watching. Though I got used to it after a while, I came across this app that allows you to manually turn off the soft key lights. Apparently it doesn't work on all phones but it works on the rezound!!!
Just make sure to set the brightness on the app itself all the way up so you don't utilize its screen filter ability (unless you want too, of course).
https://market.android.com/details?...ch_result#?t=W251bGwsMSwyLDEsImNvbS5oYXhvciJd
