Help Many problems (video recording not working etc.)
Forwox
After using my HTC Desire for who months I got very annoying and strange problems with my mobile phone:
*Video recording not working (hangs on after hitting home button)
*HTC Sense clock widget won't scroll hours, minutes at screen refresh (lock/unloch)
And some other problems. I have HTC Desire running 2.2 Android.
Have you tried rebooting your phone?
if you have then try shutting it down remove the battery & then replace battery & start the phone.
Final thing to try is a factory reset or if you are rooted try reinstalling your rom
Yes, I have tried rebooting my phone for billion times, factory reset, battery removing. But video recording is still not working. (holds on when press Record, then phone slows down). HTC Sense weather+time widget on main screen is like frozen with no animation. (all animations turned on)
I have found some information, that very similiar problems are caused by OTA upgrade (2.10.405.2) Is it possible to revert that change? Because previously there were no such problems. :(
Okay, well, video recording problem solved by deleting one of the latest video. Looks like it's not possible to get much help in this forum at all. Sorry.
You need to make more sense of what you are saying. And you wont get much help with that attitude
to be fair, its sunday and your asking for help barely and hour from the last time you asked....so how bout you cool it a bit, most of the senior advisors are probably enjoying their day(s) off.
So just hold fire and be patient.
