Alright so I was putting some music onto my phone (internal sdcard) from my computer using the usb mass storage setting. Right after I did that, I shut off pdanet (which I have used for a while with no problems) then went to unmount the sdcard from my computer and it reset itself. Turned back on and the internal card wasn't mounted to the phone (unplugged from the pc). So I reset the phone. Here's a list of problems I have noticed so far.
All ringtones/notification sounds changed to random stuff
Lockscreen doesn't exist (neither the slide screen or the pattern lock)
Home button doesn't work (that's fun)
Only options listed when I hold the power button are power down and sleep, no airplane mode.
When it first turned on, the gps had been shut off and wifi turned on (always have it set the other way around)
That's all I know of so far. I'm running SteelDroid 3. I've never had any problems with it in the past. Except for the fact that my nandroid backups don't work, so I have nothing to restore.
Any fixes for this or am I gonna have to re-install SD3 or SBF and re-root?
Thanks for any help.
